How to change throwout bearing
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
How the heck do you change the throwout bearing on a M50 slave cylinder?
I have the slave out and not sure on how to pull the bearing off.
pillen140
45
winston-salem, NC
Its one unit. Thats how mine came anyway.
pillen140
45
winston-salem, NC
P.s. I would change the whole slave anyway.... They are prone to failing.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
I have a fairly new slave with a broken bearing. Was wanting to just replace bearing if it could be done.
cocoasranger
5
south central Pa.
There is a snap ring holding the bearing on the slave, but I would do as pillen140 suggested and replace both. I had to drop the trans a second time trying to save a couple bucks and wish I had put in all new.:bawling::bawling:
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
If I recall correctly on the "Aluminum" 1988-92 slave it's a matter of squeezing the plastic retainer at two points to release plastic "Barbs" that hold the bearing retainer to the slave body.
On the 1993-up slave cylinder you depress the throwout bearing and remove the spiro-lok that holds the bearing on the "pilot"
I don't recall if there was a retaining ring on the '88-92 type or not...
as a note, the '88-92 T/O bearing is usually mounted on a BLACK plastic retainer.
The 1993-up is blue plastic, the two types are NOT interchangeable.
AD
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Cool thanks allanD I will just change both. I really dont' want to have to pull the tranny down the road. I can spend the extra money but would rather put that towards a new clutch or something needed more....
Roger
Tooele, UT
2.3
We changed just the bearing, now wish we'd changed the whole shebang...
escort_gts
16
Fort Wayne, IN
4.0, 5.0
well I have just bought a new slave. My luck it will go out as soon as I get the transmission put in.
kwikwitzkc
I have a new after market T/O brng. blk housing has (4) external barbs holding brng which must be released to install on slave, then brng can be put on and snapped back on barbs.
Kirby N.
March Truck of The Month
