Bronco II wheels on ranger?
Mr.Hotrod
I have an 88 Bronco II with stock wheels and i was wondering if i can put them on my 1987 Ford Ranger 2WD that i got for $300. and it needs wheels bad because 1 is 15" and has a bad bead in it. Will it fit? thanks
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
that's a confirmitive
kimcrwbr1
46
maplevalley WA
2.8l
I put the B-II wheels on my 83 ranger, I changed the speedo gear in the tranny to get it closer. Went from 14" stock to 15" with not alot of difference in the foot feed or MPG.
Nope. Absolutely no way they will fit. It's not like they are the same vehicle or anything.
PetesPonies
25
east coast
2.3l
here you go . . .
