Which spark plug wires, distributor cap & rotors are the best?
fleck
Florida
Mazda
Another one for the 'what's the best to use with my truck' series of threads, I will be doing these 3 items soon and was wondering what everyone suggests. I don't want any fake 'performance' products with bloated prices, I want to get the regular priced stuff (not necessarily 'cheap', even though I settle for spark plugs that cost a buck and some change), but at least the cap & rotor have to be proven in reliability.
I was looking at AutoZone for wires first and ended up at Advance Autoparts, they have the Autolite wire set for $22 so I figured since Autolite is Motorcraft it might be the best thing to get especially since I use Autolite plugs and I don't want to spend $40 on plug wires anyway.
For the cap and rotor, I am thinking of going with the Accel or Niehoff kit. NAPA only has a 'cheap' set and a 'regular price' set, one with serial letters MPE and the other ECH (?). There are other brands I'm looking at: Advance has the Borg Wagner, Beck/Arnley, and Niehoff kits; AutoZone has their own Duralast cap as well as a Beck/Arnley cap and offers Mallory (same as Accel) rotors.
Just wondering what your opinions are. Thanks.
rurouni20xx
natchitoches, la
3.0L V6
i would go w/ the autozoo beck/arnley setup as this is fine, i have one on my trk and its been good to me for 55k miles. the motorcraft (factory) stuff on my trk finally died at 225k, the tips on the coil/cap corroded in half and wouldnt take new wires, so i changed the coil/cap/rotor/wire assy w/ autozoo parts at 225k miles. i planned on doing the maintenance b4 hand, just slipped my mind til about 195k miles, and when i went to put the wires on they kept popping off the terminals so i took the wires back and put the factory ones on since i didnt have the money to change everything, and slipped my mind again til the trk would crank unless my main wire from my coil to the distributor was in a certain place and kept falling, trk would die...very interesting 5 miles to the shop to get my windshield changed to say the least. got the stuff and changed it after my windshield was put in and ran like a raped ape ever since. i was planning on using the accel 40k coil and cap/rotor assy w/ larger wires to help my boosted engine but i need to do some more reading b4 i set my mind on spending the money on that or something better.
fleck
Florida
Mazda
Alright that's two for Beck/Arnley, which is pretty good. They got the cap for $21 and the button for $6 so it's not a wallet sinker.
Have you guys heard the way this guy talks? It's great.
valleyvinyl84
Old Forge, Pa
Ford / Chevy
2.0 / 350 CID
Blue Streak! :headbang:
trish
hummer
you should also replace the rotor inside the distributor cap. Try to tune-up your car it includes plugs (NGK or Denso), wires usually OEM, distributor caps and rotors preferably OEM for both. Use platinum plugs and leave them in along with the wires for 60k or 90k, as specified by the maintenance schedule.
wahl_7s
Whittier, CA
FORD
6.4,3.0,3.0,4.0SOHC
I'm a firm believer in original equip. from experience motorcraft platinum plugs,O'rielly sells them at a reasonable price. don,t skimp on wires either if you don't get Motorcraft get a good fitted set no headaches
chazzone
9
Camby, IN
Nothing better than Motorcraft ignition parts for our trucks.
Accell is total crap, btw.
-zz
psykostevo
Phoenix, AZ
3.0L
Glad to read the advice to stay away from Accel. I was once tempted.
Kirby N.
March Truck of The Month
