remove trans and leaving tcase in the truck?
Boggin
48
is it possible?
i have the motor out of my 79 bronco, and its a bitch to put back in and line everything up with the trans still attached in the truck. so can i unbolt the trans from the crossmember, unbolt it from the tcase, and let the tcase sit on the skid plate and just slide the trans ahead 6 or 7"?
thanks
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
if the motor is already out,you can do it.
Should be able to. I still can't see that as being easier than re-attaching/adjusting the t-case shifter.
Boggin
48
thanks guys
gwaii
2010 OTOTY Winner
66
haida gwaii
460
this is sort of what i was thinking....but it's not what he asked.:icon_thumby:
Boggin
48
haha you know it man
Pt_Ranger_V8
FullsizeFreakin'
U.S. Military - Active
Forum Staff - Retired
in ur g'rage, uzin' u're toolz
19 something
Don't bother with that.
With a hoist on the engine, and a floor jack under the tranny, you have PLENTY of room to line up the engine and tranny. If you're REALLY concerned, 6-8" of allthread on two of the boltholes makes life easier as well
Boggin
48
i have the motor hanging from a chain hoist on the roof and i have a jack under the tranny but its damn hard to line up the torque converter on the trans with the flex plate on the motor. and the exhaust manifolds keep getting in the way and hitting the motor mounts. its a pita
Will
514
Gnaw Bone, Indiana
Toyota
What is that, a 351? You don't need a chain hoist for anything that small. Just get in there and man-handle that bitch. Punch its valve covers in and then bite it on the EGR valve.
PaleBlue90
5
Aurora Colorado
FORD
2.3,2.9 and 4.0
+1 by doing it you would be good at doing it afterwords:headbang:. it can be done both ways but i would rather just do what will said too
Toms01PSD
37
Sanford, NC
7.3
Sigged :icon_rofl:
snake
4
canyon lake tx
3.5
Would it be easier to remove the exhaust manifolds, put the motor in and replace the manifolds? Or remove the mounts, get eveything bolted up, raise the engine a little and put them back in?
Boggin
48
no i tried 1 bolt on each side of the exhaust manifolds and both twisted off. i dont wanna twist em all of, thats too big of a pain
feellnfroggy
28
Knoxville, TN
You wont get it done talking to us, this is one of the few instances I have to say get off the webz and get out there and start putting it in, just figure something out. And when your done you will have alot better idea of what you did and be able to advise someone else. But again it dont get done on a keyboard.
