96 2.3L Differences between upstream downstream Oxygen sensor Anything Besides Length
henryj10
Everett, WA
96 2.3L Differences between upstream downstream Oxygen sensor Anything Besides Lengths of wires? Broke off the down stream oxygen sensor when pulling the transmission theres no room in the thing even with its jacked.
Need to know if there is a difference between up stream and down stream oxygen sensors because alot of the sensors sold don't come with connectors on the other end and don't say wether they are up or down stream?
Thanks,
Jason
Autozone says:
Results 1-6 of 6
Bosch / Oxygen Sensor 15729
Application:
Sensor located after catalytic converter
Note:
Universal
4 wire; heated.
Enter ZIP code above to check availability and pricing
Bosch / Oxygen Sensor 15730
Application:
Sensor located before catalytic converter
Note:
Universal
4 wire; heated.
Bosch / Oxygen Sensor 15718
Application:
Note:
O.E. type
Exact Fit
Bosch / Oxygen Sensor 15717
Application:
Note:
O.E. type
Exact Fit
Denso / Oxygen Sensor 234-4210
Application:
Note:
Universal
Denso / Oxygen Sensor 234-4609
Application:
Note:
O.E. type
thats the point but whats the dif? last time i checked a hego narrowband was a hego narrowband, is there a dif in range that it reads or is it the same and the wire or element size dif?
Yeah great the catalog from autozone specifies down and up stream. But when you live in Montana and the 1 and only auto zone in Montana in Helena is 300 miles away doesn't do much for me.
Yeah sure I could go down to oreilly or napa and say hey I need a downstream oxy sensor woop dedo but I don't want to pay 70$
I asked what is the difference between a downstream and a upstream? Are they the same other than the length of the wire? or are they mechanically or electronically different?
I'm wondering because they're are various products online with out the connectors that you RE-WIRE to your original plug and wire FOR LIKE 19 BUCKS just the head of the actual oxygen sensors and 4 wires sticking out the a#% end. Again I need to know the differences because they do not list up or down on these sites, which makes me think there is no difference besides the length of the wires?
Thanks,
Jason
I'm in kalispell mt, and I got a new downstream O2 for $44 at Napa about 2 months ago for my 2.3. Should not cost much more than that.
