- Aug 8, 2012
- Manual
1988 Ford Ranger 2.9 V6 4X4 5 speed. Died as if out of fuel. Started checking, replaced both fuel pumps, fuel filters, distributer cap, rotor button, plug wires, took ICM to auto parts and had tested, 3 tests all showed ok.
Engine will start, run a couple seconds, then die, continued cranking it sounds as if it is trying to start, but won't. Let sit for several minutes, starts, runs a couple of seconds, dies. Having someone crank while spraying fuel in the intake, it runs perfect, stop spraying fuel, it dies. Is something cutting off the injectors? Since it starts and runs for a couple seconds, it sounds as if injectors are working at first. Also, if you pump accelerator rapidly, it will barely run as long as you keep it up. Somethings crazy here, either the truck or me! Please help.
