Desert Racing - 2WD or 4WD?
Here is a poll for those of you who follow desert racing;
What do you think is better to build, a 2WD (lighter) or 4WD (to help you get out of some of the nasty stuff)? |
2 wheel drive for sure...figure if your main rate of speed is fast enough to be competetive, and your terrain is what your perunner is set up for aka DESERT, you won't run into any place you wld need 4 wheel drive...to engage it you'd need to stop or slow down...in a race that's time determined. the extra weight wouldn't benefit either. that's why prerunners r 2 wheel drive right?
Two wheel, it's classic, doesn't hit as hard off jumps, cheaper to fix and less things can go wrong. Basically everything you could get yourself into in the desert could be fixed with a good locker, extreme screw ups with a winch. What's the point of light-weight parts and fiberglass body panels if your just going to weigh it down with 4x4 anyway?
Honestly, I'd be the guy Rockin' it in the Subaru. To hell with all you ranger people! (Only kidding, I love my 2wd Ranger.) |
4wd for when you run off the course.
4wd....Need a way of getting traction. There's a reason Trophy trucks outrun everything else, you need to be able to put the power to the ground. Lightweight parts allow 4wd to be used without a real 'weight penalty' as compared to a stock 2wd.
-andrew |
I voted 2wd. I've run both in the sand. When you are talking about racing, you are talking about speed. At speed 4wd doesn't help you. The lack of weight on the front end does. Weight doesn't help you in the sand. Lighter the better. Desert racing also means air, the less downward inertia, the easier it is on your body.
If you were talking about exploring untrailed desert, It would definatly be 4wd. Without question. |
2wd.
lighter - lighter landings, doesnt sink as far into the sand, and higher power to weight ratio. less parts to break. less unsprung weight on the front axle means better soaking of bumps and jumps. easier to get extremely long travel out of. and 4wd is just not needed for high speed desert racing. |
4wd for desert racing.
2WD for all the reasons I can think of but I'll take 4WD so that I can get through the silt beds, or around all the stuck 2WD rigs.
Yes, I have run both. |
i'd run 2wd. if you have the 4x4 then your going to go places that you might get stuck{ could be fun} but the 2wd makes you think quicker so you don't get stuck and have to use the shovel..
in most races its not often to find places that you need 4wd. i would go with 2wd just for the fact that when you jump your front end wont dive quite as hard. its also cheaper and less parts to break.
Quote:
| All times are GMT -5. The time now is 06:48 PM. |
