The Ranger Station Forums
The Ranger Station Forums (http://www.therangerstation.com/forums/index.php)
-   Need Urgent Help Fast! (http://www.therangerstation.com/forums/forumdisplay.php?f=144)
-   -   not charging (http://www.therangerstation.com/forums/showthread.php?t=149210)
joey7478 02-14-2014 03:49 PM
not charging
My son 93 ranger charges enough to keep the battery charged but when you turn on lights or heater doesn't. we had alternator checked on the truck and they said it was bad.We got new alternator and it still dose same thing. Any thoughts? Thanks Joey!
black_demon69 02-14-2014 06:02 PM
Quote:
did you check battery also? now you might want to check wiring also (could be cause for alt not working to begin with)
RonD 02-14-2014 07:24 PM
You need a volt meter.
Test battery voltage with key off
12.3 to 12.8 volts is what you need
Start engine, check battery voltage again
13.5 to 14.8volts is what you need
After idling for 2 or 3 minutes voltage should come down to 13.5-13.6volts
If this isn't happening then with engine off but key on check the green wire on the 3 wire plug on the alternator, it should have 12volts(battery voltage)
This 12volts comes from the key switch via the Voltage meter on the dash.
This 12volts turns the alternator ON, yes alternators have on/off switch.
Next to the green wire there should be a White wire, it should be a short wire run to another connection on the alternator, make sure this wire isn't frayed or loose at either end.
Next to the white wire is the Yellow wire, it will connect to the Big Red wire coming from the back of the alternator, this connection might be at the alternator or at the starter Relay on the fender.
Follow the Big Red wire, this one sends out the 13.5-14.5volts, make sure the wire is in good condition, at the opposite end from alternator this wire will be connected to a fuse or Fusible link(slightly smaller wire) and then to the "+" battery cable, usually on the Starter Relay post.
HMFM Miller 02-14-2014 08:42 PM
I know it seems trivial but make sure your terminals are clean on your battery and make sure the connections are tight there as well.
1999-2018 / 959 Media LLC / All Rights Reserved
