- Apr 18, 2010
- Automatic
98 Ranger, 4.0l, auto trans, manual hubs (yay) xlt etc.
Today it decided to snow before I could test out the 4wd to make sure it works, and sure enough, it's not...
Anyway, not sure wtf it is as I'm limited knowledge with 4wd. I'll start here, This past spring when everything was thawing out, i got the blinking 4hi/4lo lights, came to this wonder site and found that is caused by a faulty shift motor. So I ordered one from rockauto but by the time it got to me, the lights stopped blinking..
Went to a little mud hole just to see, and sure enough, everything worked fine.
being I live in NJ, and there is really no place to use my 4wd (and my mud hole got shut down) I haven't use 4wd all summer. so I never replaced the motor. Today, with the snow I decided I wanted to drive around, well I damn near got stuck! knowing that is not how my ranger acts in the snow, I clicked 4hi, sounded like everything was fine, but it was still slipping and sliding.. ( I used 4wd a lot last winter with NO issues at all)
Went to a local school parking lot, and messed around a little bit, put it in 4lo and it clicked, there was some grinding when it would go into gear, but then nothing. then it started going back and forth between 4hi/4lo..
SO I decided it was best I go home and park it before I ended up stuck someplace. Now I know I never put the new motor in and before I do it, is there ANYTHING else it could be? I'm hoping the motor does the trick but if it doesn't, I need to fix it. I searched the forum and didn't find anything to answer my question. oh and yes, the hubs were locked.
It's 6:30pm and I just went out to check it again, thinking maybe I'm losing my mind, it sounds like the motor is trying to engage the t-case, but it's just not going in. Could the motor be to weak to engage it?
Anyway, not sure wtf it is as I'm limited knowledge with 4wd. I'll start here, This past spring when everything was thawing out, i got the blinking 4hi/4lo lights, came to this wonder site and found that is caused by a faulty shift motor. So I ordered one from rockauto but by the time it got to me, the lights stopped blinking..It's 6:30pm and I just went out to check it again, thinking maybe I'm losing my mind, it sounds like the motor is trying to engage the t-case, but it's just not going in. Could the motor be to weak to engage it?
