Wire feed ?
mikkelstuff
468
Brighton, CO
I need to feed a pair of 18 AWG wires from the engine compartment into the cab of my 2002 Ranger XLT. This is for a switch (to a relay) to power an electric hoist in my truck bed. Is there a convenient place to feed these? Every passage through the firewall seems to be filled and sealed.
It looks like I can drill a hole above the auto trans gear shift cable but I'd rather not unless I have to.
ericbphoto
Overlander in development
16,594
Wellford, SC
6"
If your truck is an automatic, there may be a big grommet where the clutch master cylinder would have been. Usually there is one or two other unused grommets somewhere on the firewall. I'm not familiar with that year model.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Below the master cylinder should be a big rubber plug. I assume this is signal power because 18awg is way too small for a hoist. Poke through there. 18awg is way too small without a relay.
I agree, look for the plug where the clutch master would have been. That will probably be the best place to come in.
mikkelstuff
468
Brighton, CO
Thanks guys. The switch definitely triggers a relay.
mikkelstuff
468
Brighton, CO
I checked - no unused rubber plug where a clutch linkage would have run. Strangely though, to me, the auto trans shift cable runs through the firewall at about that location. I would guess Ford made one hole for either manual clutch or auto trans.
That's possible. Not having a Ranger of similar vintage handy to look at I can't offer any better ideas aside from drilling a small hole and installing a grommet.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
On my 09 the shift cable runs through that plug as well. I have several wires running through it, its plenty big enough.
mikkelstuff
468
Brighton, CO
I gave up and drilled a hole through the firewall just to the left and below the shift cable. This was easy enough and I will install a grommet and seal the hole.
Too bad though. This was so easy with my 1955 Mercury - plenty of places to run wire.
