what vehicles have something close to 52" and 47" leaf springs?
cammeddrz
23
Ford/chevy
efi 350vortec
just like the title says, whta vehicles have leaf springs in something around the lengths of 52" and also ones of 47"
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
7? to 8? and maybe some other years, Chevy ran 52" long by 2.5" wide springs in the back of the 3/4 ton 4wds.
I think Ranger rear springs are about 47" or around there.
What's the application?
cammeddrz
23
Ford/chevy
efi 350vortec
yeah i have a chev 3/4 ton frame under my bII and the springs are just a bit too much and it is starting to hurt my articulation. so i am looking for something much lighter-duty in the correct length
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
do what the chevy guys do, swap the 52s to the front and put 56s or 63s out back. pirate has 1001 threads on this
cammeddrz
23
Ford/chevy
efi 350vortec
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
How's your suspension set up?
Everything stock or you runnin some shackles? Flip in the rear yet?
Longer shackles will help free up some artic and give a little bit of lift. Depending on your pack, you may be able to pull another spring to soften it up. Longer shackles will make up for for the lost height due to the spring.
You could also keep the main leaf and build your own bastard pack.
Kirby N.
March Truck of The Month
