WHAT DID YOU DO TO YOUR RANGER TODAY?
Ranger850
Well-known member
579
Tallahassee Florida
Stock 2"
Stock
So good news everyone. I was able to get the old seal out. Apparently it WAS in there the whole time. Damn truck is so rusty it's hard to tell what is a part and what is supposed to come out. I didn't mess up the diff housing like I thought I did. I was actually messing up the old pinion seal thinking it was part of the housing. Popped the old seal out and put the new one in but I have a lot of back lash still when I move the flange side to side. There is no front to back play just the side to side. I set the pinion nut at the first 5 threads which is what I counted before I took it off. I've watched video's of people cranking these down with impacts and they get all the backlash out that way but I don't want to over tighten it and mess up the crush seal. So I need to just take my time and crank it slowly and try to get the back lash out, hopefully. I worked on it till about 1am trying to get this done.... It's getting old laying on a wet piece of plywood on the gravel trying to fix this damn thing.
glad to see something is finally going your way. sucks about the wet plywood tho. I use an old piece of carpet on top of plywood sometimes when the ground is too wet. Laying on carpet is a little better than the plywood, but if it gets wet too, no Bueno!
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
PacificGreen1998
Active member
67
Eustis Florida
3.0l Vulcan v6 with low miles...
stock since 1998
That one guy with ADHD and doesn't stop talking about cars.
So apparently after a few weeks of rechecking my trans fluid and trans cooler lines they seem to stop leaking now, not too long ago I tightened the hose clamps on the hoses going to the trans cooler when it just started to pour like hell....so no leaks now...anyone know why a heater in a 98 would take like 10 or more minutes just to produce heat? On subject of what did you do to your ranger today I'm finally going to wash Old Green.....phone died but later today going to post pics of my lower control arm bump stops because a piece of the driver's side bump stop came of in my hand.....least some of the ones I found weren't too expensive...going to see if my local Napa has em first before, I buy online 🤮 cuz I recently hate online shopping.......
91stranger
Well-known member
237
ohio
FORD
Mine takes about 10 minutes to get to temp unless I am driving, then it is only 5 minutes or so. That's not uncommon though. If it were 20-30 minutes then I would be concerned. You could get a new t-stat just to be safe, they are only $5-10 and only take about 10 minutes to change on the good ol 3.0. You get a hitch yet? If not, I would hit up a junk yard with an impact gun and snag one. Well worth the investment and only takes a few minutes to mount.
91stranger
Well-known member
237
ohio
FORD
Hey can anyone measure the flange on the rear end of the drive shaft for me? I need to make a brace to lock the flange so I can torque the pinion nut to spec. Based off the billion times I've removed the driveshaft I want to say it is about 3-3/4"-4" between two bolts side by side, not across from each other. I want to double check before I drill holes and I'm at work with lots of tools to do so but I don't know where to drill the holes. If not I suppose I'll have to wait until I get home. Who knew doing a pinion seal could be such a pain in the ass... That's what I get for not making sure I had a good mark on everything before removing. I'm used to learning the hard way though...
Jim Oaks
Administrator
Administrator
Founder / Site Owner
1,189
Roanoke, Texas
6-inches
33x12.50x15
91stranger
Well-known member
237
ohio
FORD
Is there even a motto for TRS? It could be "TRS...Saving one ranger at a time, new, old or modified, we got what you need" or my favorite office motto modified "you don't have to be crazy to be a member here, we'll train you" Anyone got any good ideas for a motto?
Jim Oaks
Administrator
Administrator
1,189
Roanoke, Texas
6-inches
33x12.50x15
ericbphoto
Old Redneck just wingin' it.
1,143
Wellford, SC
6"
3" side to side
4.25" across the center
On a 7.5" pinion from a 93 Ranger. But I didn't have to modify anything to bolt the same shaft to my 8.8"
ericbphoto
1,143
Wellford, SC
6"
Jim Oaks
Administrator
Administrator
1,189
Roanoke, Texas
6-inches
33x12.50x15
91stranger
Well-known member
237
ohio
FORD
Thanks that's what I needed. I figured it was around the 4" mark. I've only bolted and unbolted the driveshaft about 27 times now. Literally close to 27 times haha. Thanks again.
sgtsandman
Well-known member
601
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
I fuel up the XLT on the way home from work and pulled the FX4 out of the garage for use over the weekend.
97RangerXLT
Forum Moderator
319
Fishers, IN
2"
31"
bought a full size 31" BFG spare (on a Jeep rim). only paid 20 bucks for it, decent tread left, maybe 35%. tire is 10 years old, but for 20 bucks... now need to find someone to mount it on my extra Ranger rim
AJ
Locotomb
38
Puyallup, WA
351w
6inch custom fab lift/86
3 inch drop beams/88
35/12.5/r18
Fords and Drums
I bolted an extra axle on top of some leafs, under an extra frame (rear half) and a bed on top of that. Thinking I'm going to make a lowrider trailer to drag behind my 88 lowrider. Tomorrow, cut and turn the frame to mount a receiver.
