GreatDane
- May 25, 2014
- 0
- Ford
Hi guys
Greetings from FRF (thought it would be wise to play on two horses )
I had a ABS warning light since i bought the truck, but now i need to fix before 7July or i will loose my plates
It's a 97', 2WD, 2.3 with 4WABS ABS.
I messed around a bit yesterday, taking apart and assemble all sensor plugs and various other wire's @ the ABS system.
I switched around the relays for the 4WABS in the relay box and after i put the ignition on the warning light was gone! But now seems to throw a code?
See vid: https://www.dropbox.com/s/enfnn23am87r7ik/2014-06-14 16.21.57.mov
Of what i read it should not throw codes via warning light's as it is after 95'?
Oh, and when i put ignition on now, i can hear the relay's click in the warning compartment and they turn the warning light off, so good right?
Anyway, hope someone can budge in with advices of what to check. I will reset ECU/PCM with 2 hours, have not done that after the warning light went out!
