Speedometer
Broosedamoose
115
South East Massachusettes
4.0L SOHC
31 x 10.5
Coming in second just makes you the first loser!
I've read all the info in the tech section about why the speedometer doesn't work when swapping in an Explorer V8. But I'm still confused about something. If I'm swapping the engine, the transmission, the rear-end and the PCM, why won't the communication work? I'd be getting the signal from the same location (the rear axle) and following the exact same route as in the Explorer to the end users. I know there will be some wiring to do this but I don't see anything that shows it ever have being done. If it works in the Explorer there must be a way to make it work in the Ranger. What am I missing?
8,369
Explorers all used 4 wheel ABS
The speed signal for the speedometer(All Fords use 8,000PPM) came from the 4WABS module in 1996-2001 Explorers
In Ranger's the speedometer signal came from the GEM module, 1998-2000
BOTH Explorer and Ranger used the rear axle ABS VSS sensor as the source, but different wiring pathways and converters in those years
Rear axle VSS sends about a 25,000PPM signal, so can't be used directly for speedometer
Not sure if the Ranger 4WABS module was ever used for the conversion in these years???
That's the missing piece in your conversion, Explorer 4WABS module
2001-2011 Rangers used an OSS sensor on trans or transfer case to the PCM(computer), PCM converted OSS signal to Speedo signal, and sent it out to cluster and cruise
You lose this signal when you swap in the Explorer V8 computer
1995-1997 Rangers still had the gear driven speedo setup on trans or transfer case, no cable just the VSS was hooked up, and it was set for 8,000PPM(pulse per mile) by adjusting tooth count of the driven gear
So if you put in an older transfer case(1997 and older) with the speedo gear setup you can use that directly to the speedometer
Depends on the year of the Ranger as to how you would wire in the speedometer signal
If its a 2001 or up Ranger easiest thing would be to use a Dakota Digital SGI-5E interface hooked to rear axle VSS, also good for changing tires sizes as re-calibration is easier
I think all the Ranger 2WD automatics have the speedometer worm gear machined into their tail shafts, 1985 to 2011(A4LD to 5R55E)
So if you get an older tail shaft housing with the hole for the speedometer gear setup you could use that for speedometer signal, i.e. driven gear with VSS
win
12
Easy answer: Most V8 Explorers use the ABS system for speed signal and the later Rangers use the PCM and transmission sensors.
So, pull the Ranger's PCM and V6 hardware and the speed signal goes with them.
Pull the PCM and V8 hardware from an Expo and the speed signal stays with the ABS in the Expo.
win
12
Couple Options:
Graft in a Dakota Digital ABS/Speed signal converter.
Graft in later 4 cyl Ranger GEM module
Graft in Expo ABS and g-force modules
Graft on an earlier 4R70W output shaft and tailcone with a gear driven VSS -- some later transmissions and transfer cases have blanked off VSS hole w/correct output shaft.
Broosedamoose
115
4.0L SOHC
31 x 10.5
OK, so the ABS units are different. That's what I'm missing. I thought they were the same. I already have the Dakota Digital converter I plan on using. I was just lost on why it wouldn't work but now I understand. I would have to swap the ABS units and make my Ranger 4 wheel ABS like the Explorer. I'm sure it could be done though.
8,369
Anything CAN be done
Its "should" it be done, lol
