OkayKafka
- Mar 23, 2016
- 1
- Seattle
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3L Turbo
- 2WD / 4WD
- 2WD
This is the 1987 Ranger that I just picked up from Craigslist for $1100 dollars a couple weeks ago. I was told that it has a motor from a 1985 Mustang SVO that had the turbo taken off: but, I'm pretty sure after looking around that it is the original 2.3L 4 cylinder engine and the guy I bought it from got lied to, or lied to me. The engine works pretty well right now. Maybe running lean and needs a couple new pulleys in there.
The shifter is sloppy so I have a rebuild kit on the way.
So far I've just been just been doing some of the stuff that should have been done a while ago. I found out pretty quickly that pretty much all of the seals around the glass and doors are shot (not sure about the windshield) and were letting in water. Lots of water. Ive been cleaning up a fair amount of rust in the cab but there are only two spots so far that I have had to cut and weld new metal into. After that theres only some welding on transmission tunnel and firewall (which I may not need to do. Ill get to that.)
I replaced most of the bad seals. I tore the old ones out and I'm pretty sure that there are fossils younger than those seals. I need the rear window seal but I hacked something together that I hope will work until I have a new one.
As I alluded to Ive been doing a lot of body work so far. I welded the new panels into the floor and am filling holes along the bed where I think a canopy used to be. I really enjoy working on auto body (had plans to do it as a living at one point but life changed) so its been fun to clean up the surface rust and get the little dents out before it eventually gets painted.
Ive been working on the brakes so far since they felt mushy. Looked at and have new pads rotors and calipers on the way for the front. I tore into the rear drums yesterday and found a nice surprise. The wheel cylinder is trashed. It actually shot nasty fluid out all over the place. I have new pads and hardware along with two wheel cylinders on the way. After I get all that in I plan to do a full flush of the system.
https://www.youtube.com/watch?v=L7uEDsK01PQ
Someone ghetto dropped the front by cutting the coils. It doesn't work and seems pretty damn dangerous to me. That and it looks damn goofy as the ride looks weird and the suspension bounces.
After that Ill just be working on cleaning things up and doing a full and regular tune since I don't know when the last time that happened.
Eventually Ill be getting better interior parts. The bench seat looks like it was fed up with being sat on about a decade ago.
I need to figure out a wiring issue on the firewall. Looks like instead of putting connectors on the wires for the fuse box someone just cut a bigger hole So I have to fix that at some point.
I'd like to build up a 2.3L turbo motor but I have enough to work on so far so thats far into the future.
