Ranger revs wide open between shifts
deltas69
Gallatin Tn
I seldom come here as my Ranger's hardly have a problem..I'm on my third having put over one million miles on my previous '96 and '93 which my son is still driving. But my '94 has developed a problem with wide open throttle between shifts. 2.3 five speed, 162,000 miles runs fine idles fine..but as soon as you take off and start shirting the rpm's go almost wide open between shifts as if you were speed shifting. Coming to a stop I have to almost stall it then it will idle down correctly and idle as long as you sit still..as soon as you start..the problem returns.. I've replaced the idle air control valve, throttle position sensor, checked for vacuum leaks, ..I've replaced suspect vacuum lines, vacuum tree...etc anything associated with the vacuum system without success..It is throwing a EGR code..but..so is the '93 my son is driving and it has no problems.. In fact he just left..he's a certified mechanic on Ford, GM, and Cummings diesel and he has yet to determine the problem..other than the throttle problem, it runs fine and everything works..I drive it 200 miles per day on a parts route and have no issues other than one stated...anyone have a idea of where to look ?? Thanks for any help !!
fastpakr
2,832
Roanoke, VA
How does it behave if your simply disconnect the idle air controller?
rusty ol ranger
2.9 Mafia-Don
7,489
Michigan
177 CID
It could be the EGR sticking open and creating a massive vaccuum leak
Josh B
1,986
Oklahoma
Maybe that's why! Check in more often and you might find all kindsa stuff it needs :)
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
assuming the throttle body isnt notchy with the cable detached....sounds like you need a new or fresher throttle cable.
ericbphoto
Overlander in development
16,592
Wellford, SC
6"
My dad had a Plymouth Volare that would do that when I drove it. Then after my second or third driving lesson, the problem stopped.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Holy Richardo Monttalban flash back Eric....
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
You mentioned a EGR code--What is it, and does it happen during KOEO self test, or during KOER self test?? (KEY ON,ENGINE OFF, or KEY ON ENGINE RUN)
deltas69
Gallatin Tn
Well...never thought of that..but I'll give it a try tomorrow when I can see..(dark now..and cold)..lol Thanks for the tip
deltas69
Gallatin Tn
egr code is 337..throttle linkage and cable are find not sticking or binding....haven't unplugged the iacv yet been working on a massive pc problem allsay...could the mass air flow sensor cause this >>. 2000 miles ago my son had to put a new head on it due to a cracked head..all new valves, timing belt, water pump. tensioner, thermostat...he cleaned the maf..as well as the egr..although the egr was not clogged..it runs perfectly except for this high rpm issue..thanks for the help
deltas69
Gallatin Tn
DPFE SENSOR PERHAPS ??? I remember replacing that on my '96 Ranger ..thanks again
