Pics wanted - 1st/2nd gen pulled bedsides
Bird76Mojo
1,265
IL
I'm sure a lot of you guys are on Facebook, Instagram, Pinterest, and other media sites that I'm not on. I'm sure in this day and age of social media, there has to be a ton of pics out there of people pulling bedsides. I've done a Google image search until I was blue in the face. I figured maybe you have better access than I do to social media, so....
I'm looking for pictures of 1st gen Rangers with pulled bedsides. 2nd gen as well I suppose..
I've been thinking about getting my 87 a little lower. Nothing crazy but just enough to change the look a little. With the rear rims I have, I'll have to pull the bedsides slightly and roll the inner lip a little to avoid rubbing. I'm NOT about to narrow my rear axle.
So, if you've got some pictures of 1st or 2nd gen Rangers only, and especially shortbed 2wd trucks, with the bedsides pulled, then please post them up!
This is the only clear picture I've been able to find so far and it's not at the best angle, and he's got it flexed out, and it's a 4x4, so...
GB :)
alwaysFlOoReD
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
GB :)
That looks like former member " sloue",s truck.
I'm sure I've seen an article or build thread on pulling bedsides. It didn't look too difficult but IIRC there was oilcanning of the metal. Seem to remember they used a hydraulic jack to push out the bedsides?
Bird76Mojo
1,265
IL
I'm 100% sure I can do it with good results. I'd also be moving them very little. I'm just looking for as many pictures as I can get before I decide to do the mod.
Oh and your memory is just bizarre man. I can't remember what I did yesterday. That's his username for sure.
alwaysFlOoReD
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I could remember his truck, I had to go back into my build thread to look up his name. He helped quite a bit when I was building my Race truck.
Bird76Mojo
1,265
IL
Anyone? Bueller?
SenorNoob
567
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I only have the vaguest idea of this even is? How's it done? Looks like the bedside is stretched out?
Thinking it might be a great way to fix my lack of small fender flares.
Bird76Mojo
1,265
IL
You typically cut the metal plate underneath the wheel well that holds the outer bedside panel to the inner panel, and remove the metal support straps holding the bedsides from vibrating, then use some plywood to spread the load from some small bottle jacks. Then you'd weld some small pieces of steel across the gap in the plate you cut in half earlier. (under the wheel well)
The straps will also have to be extended before bolting them back up again.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Not sure if there are any around still of mine.....front fenders are stepped out and rears were typical pull.
Trs 2 has pulled bed sides.....now that I am thinking about it....I seen the new plates I brought home to re do them were on the floor when we were working on my sons 125 before I left for work today....damn it....one more thing that needs done.....
Bird76Mojo
1,265
IL
I'd love to see some first gen 2wd street trucks with it done. So far, I've only seen one street truck and it was lowered a good amount, but it was a newer generation of Ranger.
I figured in the modern day and age of social media that someone had seen a few on there by now.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
only thing i see with profile you can see.....obviously your openings will remain stock...but you can bulge some sticky wide fatties under there for wheelies if you want them....
Bird76Mojo
1,265
IL
Here you can see my wheel/tire combo on the rear:
rear tires are 275/40-17
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
looks perfect to me. unless you have to drive down dirt roads...
Bird76Mojo
1,265
IL
I get no rubbing right now, even with a decent load in the bed or driving the truck very aggressively around curves, but if I want to lower it a small amount the inside lip of the bedside will cut in to the tire.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
can you roll it? i guess it is too wide like it is if you go lower.
roll em and pull them 1/2 in to an inch will likely get them tucked and plenty of room to even auto x and still look great. i would bet most people would not even know they were pulled out an inch.
Bird76Mojo
1,265
IL
Yeah, that's one of the hard things to judge. How much some of the bedsides were pulled out just going by pictures on the net..
Just rolling the lip wouldn't be enough.
