Norman
Norman
Golden Ms.
Ranger Splash
Will a 06 4.0 work in my 1996 Ranger 4.0
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
SOHC to SOHC or OHV to OHV only
I can be done, but it is far from a plug-and-play affair.
It is close enough to look easy, but hard enough that if you have to ask how, you probably shouldn't try.
8,370
Simple answer is no
1990 to 2000 Rangers used the 4.0l OHV engines, 160HP
2001 to 2011 used the 4.0l SOHC engines, 207HP
Same displacement but different engines, and different wiring and computers to run the engine
Norman
Golden Ms.
Ranger Splash
Thank you for the info
Norman
Golden Ms.
Ranger Splash
Okay RonD if I had the wiring harness and the computer from the 2006 would it work in my 1996 ranger
8,370
If both are manual trans yes
If Automatic then you need the 5R55E automatic to come with the 2006 4.0l SOHC, wiring and computer, and both would need to be 2WD or both 4WD
Also exhaust system modification, you have to use the 4.0l SOHC exhaust manifolds
You would need the whole vehicle wiring harness, including the dash, and the fuel rail from a 97 Explorer.
8,370
Yes, 2004 and up Rangers used a different system, computer and instrument cluster need to be matched, and the Body Computer was also different, so loads of wiring changes.
So work-wise probably not a good swap to do
Norman
Golden Ms.
Ranger Splash
Ok thank you for the information it helped out a lot
