mtnrgr
- Aug 8, 2007
- 756
- California
- Ford
- Engine Size
- 3.0
- 2WD / 4WD
- 2WD
- Total Lift
- 6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
- Tire Size
- 31x10.50
- My credo
- Lord God is my guardian
Once again transmission fluid is coming up the speedo cable housing and leaking onto the dash, pedals, floormat, etc. This issue was originally in 2014. After a whole year a shop found it had mercon 5. They removed and put in mercon 3, and problem solved. Fast forward thousand of miles, and years later. This started 1 1/2 weeks ago. Some of you may remember that I had my transmission rebuilt Sept of 2018, and it has been good. This started after I changed the vss. Wanted to use Ford, nobody had it in stock. I went with a dorman from the auto part store, and that is when it started. After a few days of driving noticed this B.S. again. Over the past week, and alot of research yet again. I found some culprits of other online. I changed the speedo cable, changed the fluid mercon 3 again, changed the vss with a ford part, and no fix..yet. Have been talking with some in the industry, and they are baffled. All I have done it should not be doing this. Still seeking assistance from those I know. Need help as my truck is my only vehicle at the moment. Anybody have any ideas to wtf is going.
