Need help 02 Windstar
buell-eyed-devil
21
Wesley Chapel,Florida
FORD
5.0-ZF in process
3"body on new poly body mounts
Hey ya'll, watch this
sounds like I get to pull another trans. Yay
Ranger850
Doesn't get Sarcasm . . .
4,685
Tallahassee Florida
Stock 2"
Stock
mosquito repellant
buell-eyed-devil
21
FORD
5.0-ZF in process
Lots of it
buell-eyed-devil
21
FORD
5.0-ZF in process
Something else, if both front tires are off ground and I rotate one, will the other move?
They should. The transaxle has a mini diff in it. But there is enough parasitic drag in there that it can hold the other wheel still. If you want to try that you are best to turn the passenger side wheel by hand, it has the most weight attached.
buell-eyed-devil
21
FORD
5.0-ZF in process
Ok I can turn both sides by hand...even in park. Pulled both axles and cranked engine. Put in reverse, both sides turning. Put in park, I can turn both sides by hand
buell-eyed-devil
21
FORD
5.0-ZF in process
What have I broke?
Both sides will turn in opposite directions by hand, even in Park. It will prevent them from turning in unison though. The park pawl is up from the final drive, which like I said, is basically a mini diff, so the spider gears and everything can still turn in opposite directions when in park, just like you can spin the rear axle of a RWD vehicle with the trans in park.
What you broke is the bank. A Windstar is never a good financial move.
buell-eyed-devil
21
FORD
5.0-ZF in process
So I didn’t break anything?
I don't know that for sure. If it goes backwards but not forward something is wrong, but it isn't the pump, and it isn't super likely to be the torque converter. I've never been a big fan of the AX transmissions, but I am also not a transmission guy, most of my objection is to how hard they are to take out.
buell-eyed-devil
21
FORD
5.0-ZF in process
With axles in it will not drive in either direction
Then how do you know it was going in reverse?
buell-eyed-devil
21
FORD
5.0-ZF in process
Where the axles go in was turning. I had no way to see if I could stop them from rotating
buell-eyed-devil
21
FORD
5.0-ZF in process
What other 3.8 will work in this van?
The Taurus/Sable used them well into the 90s.
That's the only other transverse application I know of.
