Mystery parts found inside M50D-R1 transmission.
xuout1
Sandy Oregon
explorer
Finally got my under carriage pressure washed, truck put on the rack and transmission pulled out. When I opened up the trans I discovered the synchro collar for reverse and 5th gear was rounded off and should be a easy fix but what has me worried is the two small pins I found laying on the work bench after I rolled it over. They are .156 in diameter. One is just over 1/2" long and the other just under 1/2". The exploded view doesn't show any needle bearing rollers this size. What are they ?
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Those look like shifter lockout pins or detent pins. Did you remove any parts off the shifter cover?
xuout1
Sandy Oregon
explorer
I did remove the button sensor on the drivers side of the cover that has the long pin under it. Unless those were stacked up behind it.
They look like detent pins, possibly from the 5/R assembly.
xuout1
Sandy Oregon
explorer
The center shift rods use short fat pins and the 5th/rev use a ball and spring. Ends are slightly rounded on the mystery pins so that rules out roller bearing.
I have one am tearing apart once I have the money to rebuild it, I will find them when I do. I will not be able to find this thread by then.
xuout1
Sandy Oregon
explorer
I will have it back in the truck in one or two weeks. Will give a update when I do.
xuout1
Sandy Oregon
explorer
Update. Transmission back in with just replacing a gear slip ring and broken synchro dog springs. Trans works great so far and mysterious extra parts are still setting on my work bench.
