My dome light will not shut off! (fix inside)
89blacklx
Wilmington Ohio
Found my problem it ended up being the back glass switch. I cleaned it and all is good.
budgreen1986
i know this is an old thread but iv had this problem for about 5 years now and i put LED lights under the dash and took the fuse out ...lol had me PO`D but im gonna pop a fuse in it and sray it down with the PB and well see ill post back to tell ya if it fixed it or not..... :icon_welder:
HANNOCKBOY316
myrtle beach sc
FORD
3.0l
It may be an old thread but it helped me sprayed the latch with pb blaster and what do you know the light goes out. still buying a switch though thanks:icon_thumby:
duckman
va
3.0 l flex fuel
dome light not turning off
so my 2000 ranger's dome and door ajar light is staying on. i tried the dw-40 trick and it did not work for me, so can anybody tell me whetre the switch is in the door i cant find it :shout:
firstranger
I have four doors, does that mean there are 4 switches, one in each latch?
It is part of the latch.
al lafon
door switchs
Hello new here!
I just picked up a nice 2005 FX4 think the frist owner
may have got rid of for that very reason :icon_rofl:
As i found that the doors keep going nuts. Well
my doors are working fine (a little CRC):yahoo:
Waller Bill
V2 3.0
Thanks 4 the info
My dome light would not turn off so I surfed the internet to find out way. Came acroos this site and got some go info right off the bat. I will try the WD-40 and let you know what happens. Thanks
Waller Bill.:beer:
OkieGentleman
Oklahoma City, OK
3.0 L V6
Fix it like it has to last a 100 Years.
pocodiablo
I owe you a cup of coffee. After spending a lot of time last fall (2017) trying to get the interior lights to turn off in "Gertrude" my1998 Ranger. I pulled all of the bulbs and threw them into the side tray.
I decided to put LEDs in everywhere and started to tackle the problem of lights that would not go off when I read your post. Guess what knothead turned his dimmer swith all the way up last fall? I hope this finds you in good health.
Antigone61
Memphis, TN
This morning everything was a-ok with Baby, my 1993 Ranger. This afternoon the dome lights will not turn off and the back cab lights are also staying on. Will the WD 40 work on both? It rained cats and dogs this morning.
ericbphoto
Overlander in development
16,593
Wellford, SC
6"
And, did you. Check your dimmer switch?
This message composed solely of recycled electrons. Go green!
Antigone61
Memphis, TN
I flashed the headlights at the puppy sitting whining at the fence...but that switch in in the dash. I did not use the dimmer which is on the steering column. We removed the + cable from the battery so she would not run down overnight. It's still raining like all get out. If the dimmer switch does not work -as opposed to the headlights working- then what does that mean?
ericbphoto
16,593
Wellford, SC
6"
I wasn't talking about the headlight dimmer (high/low beam switch). I was talking about the dimmer for instrument panel lights. Ie; rotating the light switch knob on the dash which dims or brightens the dash lights and turns on the dome/cargo lights. Assuming your '93 is similar to mine.
marc61
Buffalo NY
my fix
i replaced the plunger switch in the door jamb. it worked.
