More tire kicking...
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The price they are asking isn't unreasonable. KBB rates mine as worth about $15,000. Other than the color, it doesn't look to be a bad truck. 120,000ish miles on the clock is a bit high after 8 years but if it was a work truck, 15,000 miles a year isn't too horrible. How does the interior look?
Frozen_Ice
4
A Galaxy far far away
3.0 L
P225/70R15
Have your pets spayed and neutered
IMO, its a nice looking truck but $13k is a lot.
I would have a mechanic check the truck and find out when the last time these items were replaced. If you dont know, have the dealer pay for it because its at least $3k worth of work to get her ready
  1. Differential fluid flush and change
  2. Antifreeze flush and change
  3. Heater core flush
  4. oil change, air filter, pcv valve
  5. spark plugs
  6. Cam shaft sensor ( this is a big one. Do it if its never been changed and only use Motorcraft)
  7. brakes front and back
  8. Front end check and or replace..see #9 below
  9. Front Sway Bar Links
    Front Lower Ball Joints
    Front Outer Tie Rods
    Front Upper Control Arms with Ball Joints
    Steering Rack & Pinion Bellows
    Front Inner Tie Rods
Some may laugh, but when you dont know the history, all fluids changed is the first thing you should do. 2ndly, check out the remaining listed items bc if you have to pay it will be expensive.
Sure you can say you will do it all yourself, but if they pay to fix stuff, all the better.
Good luck
  1. Cam shaft sensor ( this is a big one. Do it if its never been changed and only use Motorcraft)
Can you explain to me why this is such a big deal?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I think he's thinking of the cam synchro on the 3.0... otherwise I'm as confused as you are.
Frozen_Ice
4
3.0 L
P225/70R15
correct 3.0. If you dont have it in 4.0 then ignore. thx
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
So, it does have a mild tap at startup. Was a bit concerning. Going to go look at that 2009 FX4 tomorrow.
1990RangerinSK
1,312
Saskatchewan, Canada
Well, they said they'll do 12300... I'm going to sleep on it.
Talk me into/out of this one guys ?
It doesn't have a 2.9 in it, and you're looking at buying it? You sure you haven't lost your marbles?
Uncle Gump
Token Old Guy
13,458
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They make bolt on super charger kits for it...
After he buys it and doesn't put it on.... I was gonna buy it on the cheap.
No need here for a 2.9L super charger.
07nhbpsi
17
Monroe mi
This tap u speak of, how long did this thing sit since last run? When I got my 2010 it had been in the lot for a few months it did tick for a second or two when I first started it, and only will do it after it’s sat for a couple wks.... I’ve put 68k+ on it since then, no issues whatsoever.... Btw. I too think that price is abit high too..I’d say $11-11.5k tops...
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
May or may not have a Banshee kit on the shelf. Not saying.
Saddle Tramp
748
Florida
How was the FX4?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Well.
At 12,200 I can't pull the trigger.
Yeah, it's a nice truck. But for 12,200 I think I can do better.
Going to go look at the fx4 in Erie over the weekend. Made them an conditional offer via email. Let's see how much rust it has...
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I'll sell you my truck for $23,500.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
