Misfire
Mikes2003
Colorado
Good afternoon everyone, I've been having a misfire on my 2000 Ranger 4x4 3.0 #4 cylinder and cant figure out what it is. I have replace plug wires, plugs, the fuel injector twice and still doesn't fix the problem and I have spark at the cylinder. I took it to a shop and they said it was the injector and said the ohm reading was high. Any help would be appreciated.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Let's start with what engine you have.
Mikes2003
Colorado
lol, sorry. I have a 2000 ranger 4x4 with the 3.0
JeremyS
5
Indiana
Do a compression test. If you don't have a tester you can loan one from AutoZone. I just went through this, a misfire on #5, and it was a bad exhaust valve seat. I actually had two cylinders with low compression. If compression is good then I would test vacuum.
You can also try swapping plugs and injectors to a different cylinder to see if the problem follows it.
Mikes2003
Colorado
So far the compression is good, im going to try the swapping of the plugs. I smell gas so Something isn't firing,
JeremyS
5
Indiana
Have you swapped the wires on the coil pack to see if the misfiring cylinder follows the swapped wire?
Mikes2003
Colorado
I have so far changed wires and plugs again, new coil pack and swapped injectors from 4 (the problem) to 5 and its still at #4. I noticed that my gauges are acting funny so it might just be electrical. I was told that number 4 ohm reading at the injector was high and don't know what that means.
