Rolandtd
- May 1, 2017
- Reaction score
- 0
- Make / Model
- Mazda
- Automatic
Hey everyone ive got a lean issue with my mazda b4000 4.0 v6, that has gradually gotten worse. Originally it would surge then bog and if i feathered the gas eventually itd be stable enough to drive but yesterday it gave out completely and would only start and immediately bog out. ive checked codes and originally had p0171 and p0174 which indicated lean. after searching through the forums i checked for vacuum leaks with smoke and starter fluid with no results. Also by looking through the forums i saw something about a pvc elbow from drivers side to pass side but i dont have that line anywhere on mine. today i threw an iac valve at it since i could hear a nice bit of air being pulled through. truck still had the same issue but after keeping it alive with starter fluid it was able to somewhat idle still has a bog under any throttle. after i got it idled i pulled codes and got p0171 p0174 p1130 p1131 p1150 p1151. i figured id post here before tearing the intake off and doing the gaskets to see if someones dealt with this issue.
Also have poked the fuel shrader valve and replaced the fuel filter
thanks in advance for any advice.
