Looking for a Write up with illustrations for bagging I beam ranger
Audiotech80
New member
Michigan
Seeing if anywhere in this forum someone has given a write up or at least some photos of notching frame for tie rod clearance on dream beams or chassis tech beams . Another knowledgeable member said Chasis tech drop beams may be better .. His ride never needed to have any extra shims or relocated mounts for tie rods or anything that the chassis tech beams kept every other suspension part in Original location. Other vids I've seen show people on gen 1 gen 2 rangers notching the area above outer tie rods for clearance. Not sure if this is only a factor if you weld the bag brackets higher for a lower drop .
Any thing helps as far as the front setup on 83-94
