Well, i tought about the pan gasket, but it does'nt leak. I ordered a valve cover gasket, witch leaks a bit and the oil mess on the other side comes from the oil cooler lines. I will change those tomorrow. the power steering hoses are there and are plug'n play.
Right now, i'm on a time restreint. (i just sold the house, moving before june first)
I need the engine in there before i move. Even if it's not running, i can have it towed to my new place to continue the job.
I will change the timing belt and install gauges after she's up and running. I tought about doing the belt while it's out but if i have a no start issue after everything is done, i don't want to have too much stuff to rule out.
the intercooler i'm using is top-mounted, it'll be another project by itself.... i'll have to change piping sizes to match, make brackets and put a working hood scoop.
