HYDROBOOST BRAKES?
JOLENE_THE_RANGER
204
long beach, ca
has anyone converted to hydroboost brakes? im wondering what steering pump i need to do this conversion or if i can some how use my stock one (4.0 ohv)? i found that some mustangs came with hydroboost set ups so id probably use one of those.
any help is appreciated. thanks!
Uncle Gump
Token Old Guy
13,427
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
What advantage are you looking to gain? Mind you I've never flown a Ranger through the dessert.
In my mind... I see something like @BlackBII did with the electric power steering and loosing the P/S pump all together.
JOLENE_THE_RANGER
204
long beach, ca
room under the hood for shocks and tube work. the brake booster is right in the way of necessary tube work for shock towers and correct shock placement! my only option is with dual master cylinder manual brakes from like tilton or wilwood, or maybe a hydroboost set up if anyone's got any info on it.
Uncle Gump
Token Old Guy
13,427
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Now I see... figured it had something to do with being airborne.
I have run dual masters with a balance bar in a couple off road buggies with great results... However buggies are pretty light in comparison... and leg fatigue is a real thing.
JOLENE_THE_RANGER
204
long beach, ca
yeah id like to keep power brakes if possible. my question is if the ranger steering pump puts out enough pressure to run brakes too, or if ill have to upgrade it. through research ive learned that high pressure line runs from pump to brake booster then another high pressure from booster to steering box. and then just low pressure lines from both units back to the pump.
side note ive been reading that people do the van steering pump upgrade?
alwaysFlOoReD
5,081
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I gained some room by using a different booster. IIRC it was from an early b2. It's shown somewhere in my build thread. If I didn't have to leave right away I'd pull up the pics.
JOLENE_THE_RANGER
204
long beach, ca
so upon reading more the saginaw pump upgrade is no more. "that guy" on here was making brackets for a gm pump but im not sure if hes doing that anymore. any other options?
Stock Ranger PS pump should do the job. In 99 you could get a 3.8 Mustang with either hydroboost or vacuum boost. The 3.8 used the same steering pump as the 4.0, and the parts listings I have don't differentiate anything on the PS pump for hydro vs vacuum, they just list the one pump.
Bird76Mojo
1,265
IL
JOLENE_THE_RANGER
204
long beach, ca
damn electric brakes?! thats way cool. but way not in the budget haha!
JOLENE_THE_RANGER
204
long beach, ca
stock ranger pump is the loudest thing on my truck right now. is it cuz age? fluid? any quiet options/ brands?
BlackBII
Ranger Custom
Truck of Month
982
UT
Age, fluid and air. If you successfully vacuum bleed the air out of a ranger pump you can get it almost silent. Almost.
