Fuel injector problems??
fordalltheway
A few weeks ago my v6 3.0 in my 99 ranger start to run real rough, check engine light came on. Reported one code with a misfire on cyl #1. The injector was reading open with a multimeter. So I decided to replace all 6 fuel injectors. I used a Standard motor products # FJ712T as I was told by the distributor that's what I needed. They looked very close but quite the same as the original ford one especially the nozzle. Put them in reset the light and all works well, Smooth idle all fixed. A few miles down the road the check engine light comes back on this time with codes PO171 and PO174, lean fuel. I've checked everywhere for vac leak and loose hoses... none. I'm pretty sure the intake gasket is good (I replaced it). Is this the correct injector? Does it not like them because they are not ford injectors? Maybe the MAFS is bad?? Seems a little hard to believe. It is running 100% normal. Anyone had problems with after market injectors?
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Is your PCV valve and PCV hose in good working condition? I've seen a PCV issue throw these codes before, only on a 4.0 liter.
fordalltheway
PCV is good. Good thought...
I investigated more and I have the wrong injector. I called the distributer and they said oops we sent you the wrong thing.. we're sorry. I should have SIFJ305. The other is for a 94. The bad thing is the wrong one looks very close, fits exactly and even runs well. I considered taking it to a shop playing dumb and saying the check engine light was on and letting them figure it out. I bet that would have made them pull their hair out and charge me with a bunch of new sensors.
