Frame rust how bad is it?
Lewy
East Brunswick, New Jersey
Mazda
I just re-watched the first video he posted. When I see that frame flex in his hands, it scares me. In my opinion, it needs some serious repair/strengthening. But replacing the whole back end of the frame would be better, IF the front half really is good.
Would a front end of a frame do a lot of work when rwd towing? :p
I'ma give up on this truck if its lied to me this whole time that the frame was good enough. Or if I can find a cheap frame/truck. Or turn this one into a parts truck.
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
A frame swap isn't a cheap option, especially in the northeast. Expect to replace every bolt you have to remove, a be pleasantly surprised when you can reuse a couple. It turns into a restoration, and you wind up many thousands of dollars and hundreds of hours deep into a truck still worth a couple grand max.
It sucks, but the northeast kills vehicles. The more attached to trucks you get, the worse it gets, ask me how I know
