Flywheel bolts too short?! 4.0 clutch upgrade
bbbc3
51
Tulsa, OK
2.8 V6
I’m starting the 4.0 clutch upgrade on my ‘85 2.8l. While trying to install the new 4.0l flywheel I realize the original flywheel bolts are too short. Only two threads are visible on the mounting side of the flywheel. I can’t seem to find longer flywheel bolts.
Has anyone run into this problem?
Josh B
1,986
Oklahoma
Sounds like you need bolts from the 4.0
bbbc3
51
Tulsa, OK
2.8 V6
I have looked up 4.0 flywheel bolts on rockauto and they are too small too. They show to be 23mm and I need a 40mm to clear the flywheel and have enough thread to secure to the crank.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
summitracing,,,,jegs,,,, ARP fasteners
there are lots of lengths available
flex plate vs flywheel bolts are different lengths, don't get flex plate ones.
bbbc3
51
Tulsa, OK
2.8 V6
Yeah I think I’m going to have to go with ARP bolts.
FWIW I stopped by the ford dealership and they stopped caring this bolts. He gave me the part number: e69z-6379-A
