Engine Shudders when coming to a complete stop
wheelchairdude49
New member
2000 Ranger 2.5 auto. Engine shudders when i come up to stop, then idles smooth again. the past couple of days it seems to be getting worse. I had someone tell me to pull the wiring off the IAC valve to see if it would stall. It
didn't. No codes now. Last week i did have a lean code and found the egr tube had a big hole in it. put on a new tube and it fixed the code. Don't know if that had anything to do with the shuddering. I have checked fuel pressure, put on a new fuel filter, maf sensor, pcv and 2 vacuum hoses. New plugs and wires. Anybody have any ideas on what's causing the shudder?
Thanks
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
Duane867
New member
5
Columbus
2.3L
Air filter ?
Have you cleaned the IAC ?
wheelchairdude49
New member
engine shudder
New air filter . Haven't cleaned the iac yet. Not sure what kind of spray to use. Some say carb cleaner .
Duane867
New member
5
Columbus
2.3L
Yup, or gasoline , or diesel fuel etc etc etc..... just dont drop the whole works in though.
keep the electrical connector dry.
modelageek
New member
12
Boston, MA
What were the details of the FP tests?
