Driver side front sag
ZeroHour
14
Fort Worth, TX
I'm not sure if this is the proper location for this thread since it's stock suspension, but in my defense it's 4WD ?
So I don't recall it being an issue when I first bought her but I noticed after my first off road adventure and having to get pulled out of the mud and someone's diesel was so loud they didn't hear my horn... I was drug up the entire hill instead of just out of the hole -_- The issue is that my driver front is slightly lower or seems to be than my passenger. I roughly tried to measure differences from frame to ground and coil spring heights on each side but couldn't find a difference or if I did it seemed miniscule. I've considered replacing the front springs but I've a feeling that's not the issue. It's visibly apparent, not just the fact that say you can put a first or X fingers between fender and tire on passenger side and not the same on driver, but you can see the lean, and the camber needs to be corrected to. Basically I'm wondering if anyone has the kinda front end/alignment experience that can point out something or a failure point/adjustment area I don't see or am not aware of? I'll try to get pics up tomorrow to show the trouble
Junk Collector
Truck of Month
4,775
Rapid City SD
My Explorer sat a full inch lower on the driver's side. I did a bunch of things to fix it which included various rear leaf spring mods, swapping coils, different coils, and so on. My ultimate fix was spacers from Bronco Graveyard that go under the lower coil spring cup. You start with hex spacers, up to two of them, and then round spacers until you get the height you want. I used two hex and one round. It sits just a hair higher on the driver's side now. Get an alignment afterwards.
The reason for this is the extra weight on the driver's side, which includes but is not limited to that gas tank and driver.
Hex - https://shop.broncograveyard.com/Coil-Spring-Spacers-Pair/productinfo/93535/
Round - https://shop.broncograveyard.com/Coil-Spring-Spacers-Pair/productinfo/93537/
ZeroHour
14
Fort Worth, TX
This isn't due to extra weight though. Even when I don't have a few hundred pounds in fuel, some odd 2-300 in tools, and any passengers, the sag is there. It happened after an offroading escapade and being towed out of the mud. I can also tell the difference in pics when I bought it vs now
Junk Collector
Truck of Month
4,775
Rapid City SD
I would try swapping your front springs from side to side then and see what happens.
snoranger
Professional money waster
ASE Certified Tech
13,599
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
If the frame sits level but the truck still leans, check your body mounts. Is the rubber still good/ there? Did the bracket rot and the rubber dropped through the now lager hole?
ZeroHour
14
Fort Worth, TX
Ahhhh I hadn't thought about that. I'll check that out hopefully this evening. Wanting to do new bushings and spruce things up but $$$ I tell ya
ZeroHour
14
Fort Worth, TX
A buddy of mine mentioned doing that too. If I don't find any issues with the body mounts, then I'll try that. I may need to replace them anyway because I feel like the camber is off enough that adjustable camber bolts wouldn't correct it.
