Dim dome light
Ramcharger90
1,708
N/A na
306, Bcam,
90 ranger, I checked the connections and wires already looked good and the ground. just got real dim even with the switch turned on. Any thoughts?
Nez'sRanger
68
Pennsylvania
2.9L V6
Put an LED bulb in. It should seriously brighten it up. I got the daylight brightness in mine, and it's beautiful! Those old incandescent bulbs almost seem like a joke to me! Haha!
ericbphoto
Overlander in development
16,548
Wellford, SC
3.0L
6"
Check voltage at the bulb socket when it’s turned on. That will tell you if there’s a dirty or loose connection somewhere that you need to find.
Ramcharger90
1,708
N/A na
306, Bcam,
Already did that still very dim I thought the bulb blew at first
Bird76Mojo
1,265
IL
Check the voltage where the bulb goes. Report back here.
Check the ohm level to ground. Report back here.
