Stock Manual Transmissions:
On vehicles 1983-87 having a removable bellhousing, we manufacture an adapter plate that bolts to the stock transmission and allows the use of a standard Ford bellhousing. We recommend that you use a 1987 F150 truck bellhousing. This bellhousing is only available with a 164 tooth flywheel, which may cause tunnel clearance problems (a body lift is recommended). This bellhousing has an external slave cylinder that works well with the Bronco II / Ranger master cylinder.
Vehicles 1988 & newer used an integral bellhousing & transmission. We do not offer any adapters to retain this transmission.
P/N 712541 - 1983-88 stock transmission adapter plate to Ford V8 bellhousing
P/N CF260000 - Centerforce 11" pressure plate (bolts to flywheel with 3 sets of 2 bolts)
P/N CF360049 - Centerforce 11" pressure plate (bolts to flywheel with 6 bolts evenly spaced)
P/N 384070 - Centerforce 11" disc 1", 23 spline
P/N N1714 - Clutch release bearing
