lets say youve gotton a “new” (used) vehicle, its new enough (as in 2011) to have that damn pats system, and you only got 1 key when you took delivery. youd like a 2nd key (at least) but the only way to do so is by going to your local stealership and paying nearly $150. So heres my thought, what if you could get key blanks cut to turn the ignition, then put the chipped /linked factory key underneath the plastic on the steering coulmn near the ignition lock? I could give a d@mn about pats or the stupid fob with the lock/unlock/panic buttons. Im sure its not the same key blank as used in the 90’s and before, this is for a escape btw. I think its incredibly ridiculous to pay $147 for a extra key, Im not positive this idea would work but I cant be the first to of thought about it. Anyone try this or know if it wouldnt work?
My Fit had remote start, AND PATS. The remote start has a module that overrides the PATS system, so that the engine will start.
I had two programmed keys, and one without the chip (my spare key, that was on my house keys). I never tried using the remote start to start the car, putting the non PATS key in the ignition, turning the ignition on, and then driving away. Somehow, though, I don't think it would work. I know that if I didn't turn the key to "on", and stepped on the brake pedal, the system killed the engine, so since I was already in the car, I used my PATS key to start it back up, rather than the remote start. I don't know, though, if the car checks for my PATS key once it's already running, and would shut down if I used it to turn the ignition on and then tried to drive away.
Depending on how the remote start "hands over control" once I put the key in the ignition and turn it on, that might be an option for you (and you can get into a warm car in the winter, and a cool car in the summer.
Personally, though, I'd just pop back into the dealer, and pay the money for the second programmed PATS key. Or, do like I did with the Fit. I only carried one PATS key on me, the second one was my spare key, and stayed at home, in a safe place. You don't really *need* to have two PATS keys, just the one, although I would recommend always having two keys ON YOUR PERSON when you're driving the vehicle. I had two because I bought the car new, and got two with it when I bought it.
