better handling??
fordusa67
FORD!!
hey guys,
i have a 94' ranger 4.0 2wd standard cab long bed....ive been toying with the idea of trying to get my truck to handle a little better, more like a canyon carver...any ideas??
i was thinkin about droppin the spring under the rear axle to start out, and tryin to find a rear sway bar, any suggestions or advice??
THANK YOU!!
Jake
basketranger
Dallas, Tx
3.0 Vulcan
Personally when I convert from 7.5 axle to explorer 8.8 incorporating the sway bar at same time, and due to where I work getting some air bags off of one of the wrecked semi's and also installing on rear. Sorry, all I can offer.
Sultan
Sultan, WA
Would the Explorer rear end work on an 88?
4.0B2
151
Walls, MS
4.0 v6
tech library covers this... you have to swap the spring perch to top and weld on shock tabs.
3.0ranger1227
11
3.0L
What about the Cobra IRS like the trucks b-series? it looks like a cool conversion, no bed though.
bubbafinch07
U.S. Military - Active
quincy fl
1990
200
For
4.0, 5.0, 4.6
the 4.0 ranger in 94 has a 8.8 no need for the exploder rear. swap in a decent posi like one from a mustang. maybe a 355 373 gear. swaybars, springs, some good new shocks if yours havent been changed. new bushings, maybe the high dollar neopreen? ones... this should get you started
hope this helps
edit; just seen ur sig. you already have the posi and gears. try the rest out.
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I went down the same road years ago. Here's what i did:
'99 Cobra wheels (17x8) with 245/45ZR17 tires.
3-4 drop (dream beams and flip kit) W/ new shocks.
'89 STX 4x4 front sway bar (I dont remember what size it was, but I think it was 1.25").
90 BII rear sway bar (1").
Poly bushings.
I cant tell you what the best mod was, I did it all at the same time. I can tell you there was a HUGE, HUGE difference.
straycat
77
02 06 and 2012
Jeeps
You can do anything if you have the money, Bro.........just do it!!!
