Battery Clamps?
gungfudan
19
Mississippi
Mazda
N/A
N/A
I am going to upgrade the wiring to the battery. I need to upgrade the battery clamps as well. Does anyone have a recommendation for a good set of battery clamps?
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Terminals? I use marine grade, or platinum coated on my DD Corolla, and havent had any corrosion in years.
91stranger
512
Gets Mo Chicks
They are all good if you put them on right. Even the cheap ones can last if done right. The ground wire normally gets the green corrosion pretty bad. Get some die-electrical grease or bulb grease and that will help keep corrosion down.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I just use the cheap red and black lead ones. Typically they get replaced every two or three years.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
I have military style terminals on mine.
There are many others that work good too though.
Just don't use the clamps that clamp the battery cable down with a little metal clip and two hex bolts on the end (junk). Also, lead terminals seem to be better than zinc (or whatever it is the lead-free ones are made of)
Corrosion usually comes about because of acid leakage.
On a wet-cell type battery, I always pull the caps off and wrap 1½ turns of teflon pipe thread seal tape around each plug, and then reseat the caps onto the battery case. Done right, this pretty much eliminates any leakage from under the caps (and therefore the corrosion as well).
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Batteries store electricity.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
lol... those would be the "junk" I have been using of late. That is why they just get replaced every couple of years. I may take a closer look at the ones you poster 4x4junkie.
When I had my buggy shop... I also repaired a smaller fleet of trucks and equipment. I would use the solder on terminals. They are a little tough to use as repair ends... but if you're making new cables... these are a good bet.
I like those ones. I use them with eye end cables, so I can bolt to the cable end and have a totally modular cable.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
That's a good idea I hadn't thought of. I can see how that would work a lot better than clamping the bare end of the wire in them (what they're supposedly designed for).
Solder-on ones however are probably the most reliable of any when soldered well.
Took me a while to figure it out. One day I needed a new battery cable with a battery end. I had fifty-three cents and a box of double-eyed battery cables and various repair ends that I bought on clearance. That's what I came up with.
ericbphoto
Overlander in development
16,593
Wellford, SC
6"
Genius.
