Well I hope you have a lot of time and patience basically remove the hub and press out old ball joints and press in New ones a bench mounted vice or a big c clamp will make all the difference now would also be a good time to check your front wheel bearings and replace if needed and at least pack them with new grease you will need a special 4 prong socket to remove hubs available at pretty much any parts store and when putting hub back on make sure to follow spec if not it could cause a big problem I messed up when I did my full floating rear end in my f250 HD by not following spec on the hub nut
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
