Anyone know how to hard wire trailer wire
91stranger
512
Gets Mo Chicks
So my truck has the tow package and I used to have the t-connector where you unplug the rear lights and plug the t connector in a voila you have a 4 flat trailer hookup. Well last night I had zero lights due to the plug corroding at the adapter. The other end of the plug is still good and there are 5 or 6 wires that go into a black box and then the other side of the box is the basic 4 way wiring. Is there an easy way to wire a 4 way onto this truck without botching anything. I was going to get another adapter and they pissed me off but I may still get it. I called the O'Reilly's this morning and asked if they had it and they said they "normally do but it looks like someone bought the last one yesterday" but they said they could have one by noon today. I said great, I'll be there around 2 to get it. When I get there they said, the other store (another town) has it but we can get it by 5. I was like, what the hell, you said you normally have it in stock and you would have it by noon and now your telling me you don't have it. He says "I didn't know you wanted it" and I'm like really? That's why I was calling to see if you had it in the first place. So I go to advance auto (only those two stores, three if you count Napa and want to pay double lol) and they tell me that they can't even get it at all and that it's a factory direct part. So I'm like really??????!!!!!!! How ridiculous. So I wasted a trip to two different stores and didn't get anywhere. Time is of the essence as I need the trailer tomorrow!
8,370
Trailer wiring here: https://therangerstation.com/tech_library/TrailerLights.shtml
Your 1999 is a 3 bulb system, so shouldn't need an adapter unless your trailer only has a 2 bulb system
1999 Ranger uses a Dual filament bulb for Park and brake light, and a single bulb for turn, so thats 3 separate lights on each side
But Trailers are often wired for brake and turn bulb to be shared
1 wire for park lights
1 wire for left turn/brake
1 wire for right turn/brake
1 wire for ground
In that case your 1999 needs the adapter to combine turn and brake to one wire on each side
OR you can add brake light on each side of the trailer
If you are in a real jam, then U-haul will have the adapters but usually not cheap
And if your desperate, lol.................and not driving at night, you can high jack the parking lights for use as the brake lights, so you would have turn signals and brake lights
OR if you will be driving at night then don't hook up turn signals, just have the Parking and brakes lights
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You can build your own converter with 3 relays.
Relay #1:
Pin 85 - stop light signal (from truck)
Pin 86 - ground
Pin 30 - fused power (you have to run this wire, there are no constant power wires at the back of the Ranger)
Pin 87 - split to pin 87a on both relay 2 + 3
Pin 87A - split to both pin 87 on relay 2 + 3
Relay #2:
Pin 85 - left turn signal (from truck)
Pin 86 - ground
Pin 30 - output to trailer, left turn
Pin 87 - from pin 87a on relay #1
Pin 87a - from pin 87 on relay #1
Relay #3:
Pin 85 - right turn signal (from truck)
Pin 86 - ground
Pin 30 - output to trailer, right turn
Wire the parking light and ground outputs and you're done.
