ABS sensor cable is cut
Patrologia
New member
Milwaukee
3.0L Edge
New to the forum, and new to my Ranger. I knew it had an ABS light when I bought it but wasn’t extremely concerned since the brakes work fine for normal braking. Doing some other work yesterday I saw what I assume is the reason for my ABS issue:
So my question is this. Would there be any problem with stripping back the insulation and soldering the wires rather than replacing the sensor and cable? The instructions seem to indicate that you have to remove to rotor to gain access and replace the sensor—I’d just as soon put that off until I’m replacing the rotors anyway. It seems pretty straightforward wiring, but I don’t know much about how the ABS stuff does it’s job.
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
projectRanger93
Active member
167
Los Angeles, CA
Ranger STX
235/75-R15
First I would recommend you get a wiring diagram of your ranger to understand the ABS system. If you know where you're supposed to wire/solder then by all means do it. My Rear ABS harness was torn so I just soldered it myself. I checked the wiring diagram to check before I did anything. I have a 93 so mine is probably simpler than yours.
pjtoledo
Well-known member
167
Toledo Ohio
Fords
3.0 2.3
get outta my way, I'm falling!
looks like there is a few inches missing. the cable should have a large U to allow for turning and up/down.
since that line flexes constantly with suspension movement I wouldn't have much faith in a solder job lasting very long.
being in the rust belt expect to do some digging to get the old sensor out of the hub. I've never had one come out intact.
Patrologia
New member
Milwaukee
3.0L Edge
Thanks, I’ll definitely check to be sure there’s enough play to allow for steering. I think it may look shorter than it is because of the way I was holding the wires.
snoranger
This page left blank intentionally
ASE Certified Tech
1,133
Jackson, NJ
'79,'94,'02,'17
All Fords
Yes, you can repair ABS wiring. We do it all the time at work. Solder it and cover it with heat shrink... it will last a long time.
Jim2
Honolulu HI
2.9 L
Thanks for posting this. (y)
I have to do the front pads, and the ABS light is on right now on mine.
I'll definitely look close at that stuff.
alwaysFlOoReD
Forum Moderator
722
Red Deer, Canada
'91, '94, '80
Ford, GMC
4.0,4.0,350
Use heat shrink with adhesive in it.
ericbphoto
Old Redneck just wingin' it.
1,121
Wellford, SC
6"
And make sure the finished cable will have enough slack for suspension travel, etc. Add s short piece of wire and make two splices if necessary to have enough length
sgtsandman
Well-known member
598
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
One thing I've been seeing a lot of lately in youtube videos is a heat shrink tube with a piece of solder in the middle. The solder melts when a person applies heat to the heat shrink, soldering the wires and sealing out the elements all in one shot. It might be worth your time looking into that.
bobbywalter
TRS Technical Staff
527
woodhaven mi
FORD mostly
BIGGER
sawzall?
awww hell no.
