95 Ranger 2wd 16x8 5x4.5 4: Backspace
jmkissler
Sierra Vista, AZ
Hey all! I picked up a Ranger recently. The wheels it currently has are a mismatched set of 14's. After looking at tire prices, I decided it would be in my best interest to pick up a set of 16" wheels so that tires are easier to find.
Will the specs in the title work for me? The part I don't understand, as far as fitment is the backspace. I would like to make sure I have no tire rub.
Junglejoe
66
Columbia Missouri
6.0
You can go up to 6 3/4 on the rears..fronts I'm no so sure.
Junglejoe
66
Columbia Missouri
6.0
7" wide wheel w/ 4.50" Backspacing (+12 offset) - meaning 2.50" outboard. (Stock)
8" wide wheel w/ 3.25" Backspacing (-32 offset) - meaning 4.75" outboard. (aka - 2.25" further "out" than stock as well as being 1.25" inward less than stock)
8" wide wheel w/ 3.75" Backspacing (-19 offset) - meaning 4.25" outboard. (aka - 1.75" further "out" than stock as well as being .75" inward less than stock)
8" wide wheel w/ 4.00" Backspacing (-12 offset) - meaning 4.00" outboard. (aka - 1.50" further "out" than stock as well as being .50" inward less than stock)
8" wide wheel w/ 4.50" Backspacing (0 offset) - meaning 3.50" outboard. (aka - 1.00" further "out" than stock as well as being the same distance inward as stock)
COPIED FROM AN OLD POST I had found
