89 high idle
Epixstar
3.slow
hi i have a 1989 ranger xlt 2.9 87,000 miles and i cant seem to get the idle to come down past 1400 rpms. I did i full tune up on it plugs wires and cap and rotor.i cleaned out the throttle body which was very dirty the best i can. I checked for vacuum leaks and could not find any up top. still the same idle at 1400. any suggestions of what i should do next.
Epixstar
3.slow
im looking for were the vacuum line gos were the gold screw is i pluged it. i have no clue were it go's i dont know if that could be the reason for the high idle
Epixstar
3.slow
update unpluged the iac car shut off, then took it off and cleaned it real good no difference still idles around 1400 to 1600 r.p.ms any ideas?
piotrsko
reno
11" KOSTOV 192V
if the throttle set screw isn't allowing the throttle to fully shut you can get a fast idle, as also, bad coolant temp sensor, a bad intake temp sensor a bunch of intake leaks from the various hoses around the throttle body.
Could be other things, but the fact that the IAC shuts down the engine, I think the computer senses a need for high idle and is responding as such.
Epixstar
3.slow
i was about about a half gallon low on coolant the screw is all the way backed off for the throttle and i checked for vacuum leaks on the intake gasket with carb cleaner. im hoping it is just a bubble in the cooling system i know it leaks from the water pump just a little. im gonna plate it and drive it a little bit tomorrow to see if that helps. Ill do the water pump when it warms up a little here still well bellow freezing in the motor city.
RustedRanger
5
Farmland IN
2.9L
The screw for the throttle is not for adjusting the idle....it sets the TPS. If you changed it then it will have to be reset. On mine I unplugged the IAC and it would die, I cleaned it a couple times but it was still bad. I do agree it could be the CTS,the computer might think the motor is cold and keeps the idle high. On mine I finally had it put on a diagnostic computer and found several problems, it is not cheap but it saved me time and money replacing more parts that didn't need replacing.
Epixstar
3.slow
i know it was like that win i bought it. i will have to learn how to set it
Sicktight722
Columbia & Effingham SC
2.9L
On mine. the hose that goes where that screw is goes to a T over need the fan box. Mine was unplugged for a while and I plugged it back and it doesn't run any differently. I also have a high idle. but I think mine might be from the spark plugs being out of specs on the gap.
