- May 23, 2014
- 167
- Kelowna BC
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- Around 6-7"
- Tire Size
- 38x15.5
Selling my 4" Superlift to pay for my next project. Its been in my truck for about 2 years and Ive put roughly 20000 kms on it.
Comes with all required brackets, knuckles, crossmemebers, shocks, optional skid plate and most of the hardware. For the rear end it comes with lift blocks. I have a set of unused u-bolts to go with the kit. They fit FX4 models with the 8.8 31 spline rear end.
To complete the install you will need:
-Front driveshaft with a double cardan joint for higher angles
-If you dont have an FX4 - you'll need new u-bolts
Notes:
-The limit straps included in the kit have been shortened, you will need to figure out a way to mount them
-The front diff lateral support bracket has been reinforced as it is a known weak point in these kits. Since I reinforced it, it has worked problem free. You just need to drill an extra hole to mount it.
Located in Kelowna, BC Canada. Will ship at owners expense.
Asking $900 CAD. Kit is roughly $2000 CAD new.
https://superlift.com/product-detail/K358
I can send pictures if you're interested. It wont let me upload because the files are too large.
Notes:
