- Jan 29, 2010
- 615
- Central Indiana
- Ford
- Engine Size
- 3.0
Area under the curve is one thing, and it's a big one, but based on peak numbers the 4.0 SOHC isn't really significantly more powerful or torquey than the 3.0 relative to it's size.
According to the Tech Library here:
The 4.0 SOHC had 207hp @ 5250rpm and 238ft-lbs @ 3000rpm. 51.75hp/L and 59.5 ft-lbs/L
A '00 3.0 OHV had 150hp @ 4750rpm and 190ft-lbs @ 3650rpm. 50hp/L and 63.3 ft-lbs/L
The 4.0 SOHC was designed in the mid 90s. The 3.0 was designed in the early 80s. 15 years of progress and a much more mechanical complexity didn't really gain as much as people might think. If anybody can find the actual torque curves for either engine that might show a bit more of a difference to justify the changes.
Seems like most of the 4.0 SOHCs went into heavy trucks with 4WD, extended cabs, etc. I'd bet that a 2wd/3.0/manual/regular cab truck could probably move just as well as the more powerful and torquey 4.0 truck with the extra 1000lbs of options they typically had to haul around.
