TimDaniel
- Oct 19, 2019
- 0
- washington
- Ford Ranger
Hello, trying to solve a problem with temp gauge spikes. My son has had most of the issues at college so i don't have all the first hand experiences so i traded my truck for his so i could figure it out. So I run the truck on the hwy for an hour or so and suddenly the temp gauge spikes to all the way hot. I turn on the heat full blast and the needle returns to normal. I drive 10 more minutes and the needle spikes again. Drive 5 more minutes and needle goes back to normal. Have been fighting this problem for a year now. coolant reservoir stays full. No steam. engine despite gauge does not seem overly hot. Water pump changed, two thermostat changes. vehicle towed twice when son was driving. mechanic serviced twice. Wetter water added. hydro carbon test negative. Mechanics baffled. 1st mechanic was ford dealership ex mechanic called friends in the buis and reported ford is aware of this problem and do not offer a solution. Second mechanic made sure to burp air out of system on second thermostat change in 6 months. I have found exact same problem on other forums and replacing temp sensor does not correct problem. Getting super tired of throwing darts and money at this issue. Any advice would be great. Thanks
