New ECU is in. Starts and runs like previous. Will not rev above 3000-3500 rpm, no power. When inline spout is pulled, runs like a lack of power, but will rev beyond 3000
Unplugging MAF sensor at connector does not change idle or running
KOEO:
57
Intermittent in Park/Neutral/ Switch or Neutral Pressure switch circuit
1990 Scorpio - Octane jumper installed (information only code - to inform you if it is installed or not)
16
1.9L & 2.5L - Throttle stop set too high
2.3L - RPM's too low
(O) Electronic ignition - IDM circuit fault
85
2.3L T/C Automatic - 3/4-4/3 Shift solenoid
CANP solenoid (ALL 1989)
(M) 1.9L MFI - System has corrected rich condition
89
A4LD - Converter Clutch Override solenoid
AXOD Torque Converter Control solenoid circuit
Exhaust Heat Control (heat riser) solenoid circuit
86
2.3L or 2.9L Truck - A4LD 3/4 shift solenoid
(M) 1.9L MFI - System has corrected lean condition
KOEO memory:
14
Ignition pickup was erratic
E4OD Transmission diesel RPM sensor
22
MAP (vacuum) or BARO signal out of range
45
AIR not Diverting (AIRD)
Electronic Ignition - coil primary circuit failure
66
Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low
Transmission Oil Temperature (TOT) signal low (possibly grounded)
EEC Handbook - Ford Fuel Injection and EEC IV Electronic Engine Control by Dali Design - 2 digit codes
www.thorssell.net
Called Ford dealer to cross reference part numbers. F07F-12A650-DA cross references to FOTZ-12A650-DA
Ran two different MAF sensors - An aftermarket Spectra Premium MA223, and a Ford F0VF-12B579-A2C. No difference
I'm starting to wonder if I have the MAF wired wrong. The only changes I made to my harness were to add the MAF sensor inputs and outputs to pins 14 and 15, and the MAP sensor 12V hot and ground. No other changes.
Checked MAF leads with meter. It is getting voltage and outputting signal.
Left my MAP plugged in. Disconnected the hose from the block and capped the block side.
Really stuck on this one ?
