2.3L question
Leatherneck1992
Billings Montana
I have a 1990 2 wheel drive ranger, I pulled the original 2.3L daul spark out for a swap. My question is, I have found a 2.3L single spark from a 1988 mustang, what would I have to do too swap the single spark 2.3 into my ranger that had dual spark?
scotts90ranger
4,367
Dayton Oregon
2.3 Turbo
HERE is a diagram that I found HERE
I've posted it several times and don't remember everything... I didn't go that route and used DIS on mine, but I believe that can be used to go backwards to TFI ignition
8,370
Pull out the wiring harness and computer from the 1988 Mustang and install it in the 1990 Ranger
Or get a 1989-1994 2.3l Ranger engine, the distributorless dual spark has better power and performance than the single spark
If you are not trying to get away from the dual, spark system and your 8-plug head is OK, you can always swap the head over.
8,370
The problem with the head swap is no Crank Sensor on the 1988 block
scotts90ranger
4,367
Dayton Oregon
2.3 Turbo
That does take some screwing around to fix... making a template for the crank sensor, getting the crank sensor and bracket from another engine as well as the front seal housing and the appropriate wiring and related parts as well as the oil pump drive, making a heat sink for the DIS module (and grounding it). The DIS can run off of just the passenger side coil, if you don't have a tach ground the two outputs of the unused side and cap off the power wire, if you have a tach tie the appropriate wires together for the two coils and bob's your uncle... that's how my turbo engine is running right now.
