Truckedup
- Feb 25, 2018
- 0
- Marion NY
- Ford
- Engine Size
- 4.0
I bought an 09 4x4 Sport super cab that appeared to be in pretty good shape body wise... I Removed the bed to deal with one rusted through bed cross rail....I found three totally rotted crossrails.. But far worse is the frame cross member behind the cab is totally rotted on the right side...it's right where the frame is spiced and the spring hangers are attached..This is a stress area....In addition the large stamped rear crossmember that supports the spare tire is also rusted badly where attached to the frame rails...But at least the trailer receiver hitch holds the frame rails
I have fabricated parts like this for vintage trucks but I would rather buy a new or good used frame cross member(s) if available...
Before I go around at the local Ford parts dept, do any of you know if the cross member are sold as replacement parts ? If so, do you know the part number(s) Thanks
