Suspension--Stock
Versus James Duff
(Click
Images For Larger View)
Last issue we covered
the installation of James Duff's 3" Class 2 suspension lift
and gears on my '91 Ranger. This issue, I completed the article
for the installation of the front locker--the truck was already
equipped with a rear one. Also, I had mud tires put on
the truck. Though the truck performed really well at the Spring
Round-Up, I had still not done a direct comparison between the
stock truck and the modified truck.
Before I could do
that, the urge to own a vehicle with more than 2.5 seats struck me
and I bought a Bronco II. I quickly transferred the parts from the
Ranger to the Bronco II: locked Dana 35 and 8.8" axles with
4.10s, Duff suspension, and 31" Kumho Venture MTs. Now, with
the new vehicle completed I could finally get it out on the same
trails that I tested the Ranger on and do a direct comparison
between stock and modified. In the pictures that follow, both
trucks have the sway bars removed.
There is no question
but the the Duff suspension has a ton more travel than the stock
stuff. The Duff travel is limited by the shocks being about
1.5" too short. The stock suspension was limited first by the
radius arms and then by the shocks and springs. The stock
suspension travel in these pictures was measured at 9" in the
front and 17" in the rear. I was hoping to gain 3" of
front travel and I believe I have easily done that. I did not have
a tape measure with me for the modified test but I think there is
13-14" in the front. As far as the rear goes, the stock
Bronco II springs were used and they seem to be less stiff than
the Ranger springs. The 31" tires on the Bronco II were
rubbing when the tires stuffed, but I think about 20" of
travel is present. With the Duff suspension, the truck
crawled over everything like a spider and I had to work at it to
lift a tire. With the stock suspension, three on the ground was
about the norm. I will say that even with only a 3" lift and
31" tires, the Bronco II is way more tippy than the Ranger
was with the same parts on it. I am pretty sure that I will
eventually put a Ranger cab on the B2 chassis when I get something
else to haul kids in.
But the best gains
were actually in drivability on the road. The Duff dual shock
set-up gives the truck great control on the worst of roads. I
think that since the powerful shocks actually absorb the energy
from a bumps and sways and release it as heat rather than storing
it and unloading it, the truck is much more stable. The Duff
suspension is definitely a suspension that is made to be driven:
driven anywhere.
